Help with Docker build on MacOS
Hi @pierre-gilles
I have it running quite well now. I’m checking a bit on the Zigbee2MQTT service and using the USB device at /dev/ttyACM0. I triggered the API /api/v1/service/usb/port, but I got a 404 Not Found error.
After checking, I found that UsbController failed to run due to the following error:
SERVICE_LOAD_ERROR Error: /src/server/services/usb/node_modules/@serialport/bindings/build/Release/bindings.node: invalid ELF header
    at Module._extensions..node (node:internal/modules/cjs/loader:1460:18)
    at Module.load (node:internal/modules/cjs/loader:1203:32)
    at Module._load (node:internal/modules/cjs/loader:1019:12)
    at Module.require (node:internal/modules/cjs
I researched a bit and found that this issue seems related to the build architecture. However, I built it on a Mac M1 and used the following command to build:
ARG TARGET
ARG VERSION
ARG BUILD_DATE
FROM --platform=linux/arm64 ${TARGET}/node:18-slim
LABEL \
  org.label-schema.build-date=$BUILD_DATE \
  org.label-schema.version=$VERSION
COPY qemu-* /usr/bin/
# System dependencies
RUN apt-get update && apt-get install -y --no-install-recommends \
         tzdata \
         nmap \
         ffmpeg \
         sqlite3 \
         openssl \
         gzip \
         udev \
         bluez \
    && rm -rf /var/lib/apt/lists/*
WORKDIR /tmp
# Install Gladys
RUN mkdir /src
WORKDIR /src
ADD . /src
# COPY ./static /src/server/static
WORKDIR /src/server
# Install build dependencies and application dependencies
RUN apt-get update && apt-get install -y \
         build-essential \
         python3 \
         python3-pip \
         git \
         libffi-dev && \
         apt-get clean
RUN npm install --unsafe-perm --production
RUN npm cache clean --force \
         && apt-get autoremove -y build-essential python3 python3-pip git libffi-dev \
         && apt-get purge -y --auto-remove \
ENV NODE_ENV production
ENV SERVER_PORT 80
# Export listening port
EXPOSE 80
CMD ["node", "index.js"]
Please give me advice and a solution to fix this issue. Thank you very much!
Hi @vule :slight_smile:
I made your topic public, it’s best that everyone can see your post (I’m not the only one who can answer to you!)
Why do you build on your Mac ? I’m never building on mine, just using Github builds :smiley:
See this tutorial :
If you really want to build on Mac, you need to make sure that you are doing cross compilation correctly.
Do you confirm your are building your Docker image with buildx ? not docker build ?
Make sure the node_modules from your Mac are not copied inside the container.
What’s happening here is that your node_modules from your Mac are copied inside the container and it can’t work because those are compiled for MacOS and inside the container it’s linux :slight_smile:
ChatGPT is good help with these kind of errors btw ^^
