Gladys can't connect to MQTT and Zigbee2MQTT
Hi,
I’m evaluating Gladys for personal use. I like it a lot. But since I have mainly zigbee-devices the Zigbee2MQTT option is vital.
However I encounter an error.
MQTT and Zigbee2MQTT are running, but Gladys, MQTT and Zigbee2MQTT won’t connect to eachother. What can I do?
I’m running Gladys inside Pi OS on a Pi4B, with a native Pi-powersupply and a Sonoff ZBDongle-P plugged into the black USB-port.
EDIT: I restarted both mqtt and zigbee2mqtt in docker, but the problem remains.
Then I reviewed the logs. They show repeating patterns:
mqtt-logs:
zigbee2mqtt-logs:
Hi @alpha-rd and thanks for your message ! :slight_smile:
I’m happy you like Gladys.
The zigbee2mqtt integration is our most used integration so it’s supposed to work fine. It seems there was a very recent upgrade from Mosquitto (the MQTT broker we use), so it might be linked to that.
I’ll try to reproduce and come back to you
I confirm that I’m able to reproduce, it seems there is a bug with the 2.0.16 version of Mosquitto, there are many people complaining of the Github of similar issues ( Issues · eclipse/mosquitto · GitHub )
I’ll test again with a fixed 2.0.15 version to see if it mitigate the problem, and if yes I’ll push a Gladys upgrade.
Mosquitto 2.0.15 indeed fixes the issue.
I’ve published a fix:
I’ll tell you when it’s live in production
I just published Gladys Assistant v4.26.1, and it’ll automatically upgrade your container to Mosquitto 2.0.15 instead of 2.0.16 to mitigate this bug!
Note that you may need to re-save the configuration to fix the configuration file.
Don’t hesitate if you have any questions :slight_smile:
I’ll check it and let you know. Thanks for the fast reply. I already started thinking I was doing things wrong. (And welcome back from your vacation).
It all works. Thanks.
