I’m using docker-compose to start gladys and watchtower. Using docker logs
I can see the most recent logs. Are they actually persisted anywhere? I have a volume mapped for /var/lib/gladysassistant
but don’t see any logs in there.
Hello. They are not by default.
Is there some other volume I can map to the host?
I can’t work out where they are written to.
Hi, there is no log file inside container ( console mode ), but docker daemon store the log in your host
/var/lib/docker/containers/<container id>/<container id>-json.log
If you need container id you can run this command
docker inspect --format="{{.Id}}" gladys
Thanks. So they go when the container is deleted. Is there a way to have gladys log to /var/lib/gladysassistant
instead?
No you can’t , it’s not really related to Gladys but with docker engine.
You can tweak as you need your compose file
Thanks!
I guess it becomes a docker engine thing when one decides to log everything to the console
