Sometimes a developer wants to post a “test” Docker image on the forum to allow users to test a new integration before it is deployed to production.
Unlike the “official” Docker image which is hosted on the gladysassistant/gladys
project account, a test image will be hosted on the Docker account of the developer proposing the image. Example: jeanfrancois/gladys
To launch a test Docker image, it’s the same process as described on the Gladys installation page via Docker: Docker | Gladys Assistant.
The only difference is that you have to change the name of the image in the docker run to the test image, and modify certain parameters of the command.
Before you begin
If you don’t know what you’re doing, avoid running a test image on the same machine as your production installation, as this could have consequences on your installation!
Launch test image
Let’s imagine that we want to launch a test image of the “zwave” integration, developed by “jeanfrancois”.
We will take the docker run
command on the Gladys site, and modify several things:
- The name of the container, for example “gladys-zwave-test” instead of “gladys”:
--name gladys-zwave-test \
- The port on which Gladys runs, for example 8001 instead of 80:
-e SERVER_PORT=8001 \
- The folder in which all Gladys files will be saved (database, configuration):
-v /var/lib/gladysassistant_zwave_test:/var/lib/gladysassistant \
- The name of the Docker image to launch:
jeanfrancois/gladys
instead ofgladysassistant/gladys
Which gives us this command:
docker run -d \
--log-driver json-file \
--log-opt max-size=10m \
--cgroupns=host \
--restart=always\
--privileged\
--network=host \
-e NODE_ENV=production \
-e TZ=Europe/Paris \
-v /dev:/dev \
-v /run/udev:/run/udev:ro \
jeanfrancois/gladys
To access Gladys:
http://IP_MACHINE:8001
To stop this container:
docker stop gladys-zwave-test
To delete this container:
docker rm gladys-zwave-test
To fetch a new version of the image
(if the dev has made progress on its integration):
docker pull jeanfrancois/gladys
Please note that a Docker container is immutable: if you ever pull a new image, you must stop the container, delete the container then docker run a new container
Note:
Avoid connecting your Gladys Plus account to a test instance, as this will disconnect your production instance.
