Unfortunately this feels similar to my previous issue with the hue bulbs. I’m not able to discover any of my TP-Link devices despite having them working with the TP-link app. As my as my physical setup I have my server connected directly to my wireless router via ethernet.
This is my docker-compose file
services:
gladys:
container_name: gladys
image: gladysassistant/gladys:v4
network_mode: host # Host network as it needs to scan it for devices
privileged: true
volumes:
- /data/gladysassistant:/data/gladysassistant
- /dev:/dev
- /run/udev:/run/udev
- /var/run/docker.sock:/var/run/docker.sock
Thanks Pierre! Seems I can access them directly but even when using the libraries CLI discovery doesn’t work. Browsing their github it might be something with my firewall. I’ll update if I find a solution
Alright! Didn’t get around to it for a bit but figured it out! So root issue was apparently with an install of Rocky Linux it comes with firewalld which was messing with the discovery of the TP-Link devices. So I had to open up a range of ports since the tp-smarthome-api client disovery function doesn’t define a port in it’s config (optional param). Would it make sense to allow some advanced config for the integration to allow specifying a port?
