orval
December 14, 2022, 12:37pm
Hi,
Is it possible to take the value of a temperature in a room in Gladys and send that out to Node-red via MQTT?
I assumed I could do that so set up Node-red and an MQTT broker but Gladys is not publishing any temp data.
Firstly, should this be possible? Or have I misunderstood this feature?
If it is possible, what is the correct way to configure it?
I’ll attach a screenshot of my config below.
Many thanks
orval
December 14, 2022, 12:46pm
forgot to say that the temperature devices are Zigbee and are connected via the zigbee2mqtt integration.
I think you may use HTTP In
node in Node Red to expose an HTTP endpoint.
In your scene, you can get value from a device and using action Doing an HTTP Request
to propagate value to Node Red.
Never tested, but it should do the trick
Currently, you cannot set a value from a variable in action Control a device
There is a feature request on the forum here Être capable d'injecter une variable dans requête HTTP + contrôler un appareil - Demande de fonctionnalités - Communauté Gladys Assistant
orval
December 14, 2022, 5:07pm
Thanks! I got that to work using a scene triggered on temperature change. I had misinterpreted the MQTT API page in the docs
