Hi everyone. I thought I would try to install Gladys on a whim, following these directions - Deploy Gladys on a Synology NAS with Docker | Gladys Assistant
Everything seemed to be working fine until i got this error at the end of the installation process.
I’m not sure it finished installing because I can’t launch it via my IP/ports.
I’m not sure what my next steps are here. Any help is appreciated.
Thanks
Hello and welcome to the Gladys Community
Can you tell us more about your NAS device ?
The directory /etc/timezone
seems to not exist, and so the docker is not able to launch.
Can you try to replace this line
-v /etc/timezone:/etc/timezone:ro
by this one ?
-v /etc/TZ:/etc/timezone:ro
What do you need to know about it? Do different synology NAS install differently?
Synology Device and DSM versions could help to reduce the possible errors and help you better.
DS923+ DSM 7.2.1-69057 Update 3
Ok i will try that.
Do I have to remove or rename the container “gladys” that was made during my first attempt? If so, how do I do that?
Also, I got to step 4, but there is nothing labeled “stacks” on the left column.,
Nevermind. I’m setup now in Gladys. Thank you for your help.
Amazing !
@Dukefrukem if you have any questions on Gladys don’t hesitate to create a new topic
