Gladys Assistant 4.56.1: Fix for Gladys Plus Disconnection Bug
Hey everyone! :blush:
I’ve just released Gladys Assistant 4.56.1, a new update that fixes an unexpected Gladys Plus disconnection bug introduced in version 4.56.
The update is rolling out automatically to all instances within the next 24 hours.
If your Gladys instance is currently disconnected from Gladys Plus and you want to force the update manually, you can run Watchtower with the following command:
(Prepend sudo if your environment requires it.)
docker run --rm \
    containrrr/watchtower \
    --run-once
(FYI, I’m working on adding a button in Gladys to easily force updates in the future! :blush:)
Sorry for the inconvenience, and thanks for your patience! :pray:
Have a great Sunday! :rocket:
