Hi all
New update from Gladys, with some nice improvements
Chart colors
You can thank @GziAzman for this feature, itโs now possible to choose the color of each curve on a chart :
Zigbee2mqtt: Compatibility with NEO sirens
The NEO Zigbee siren is now compatible with Gladys
Thanks to @_Will_71 for the PR
Investigation bug alarm disconnection
Iโve made a small patch to try and fix a tablet disconnection bug in alarm mode raised by @spenceur and @philou
The complete CHANGELOG is available here .
How to upgrade
If you have installed Gladys with the official Raspberry Pi OS image, your instances will update automatically in the next few hours. This can take up to 24 hours, so donโt panic.
If you installed Gladys with Docker, check that you are using Watchtower (See the documentation )
The complete CHANGELOG is available here.
