Hi everyone!
New Gladys release today: Gladys Assistant 4.38.1
This is a release that brings quite a few fixes:
- It’s now possible to use end-to-end encrypted camera streaming on iOS!!! Apple has (finally) released the MediaSource API on iOS (which has been available on Safari and iPadOS for a long time), which now allows us to do end-to-end encrypted camera video stream streaming on iPhone.
- OpenWeather: Fixed a display bug on the hour-by-hour display.
- Zigbee2mqtt: Added compatibility with IKEA Somrig button
Thanks @_Will_71 for the PR
- The map now zooms in on the area where your house and zones are when the map is displayed
You can congratulate @GziAzman on his first development on Gladys!
- Zigbee2mqtt: In the integration configuration page, the battery of each device is now displayed! Thanks @_Will_71 for the development
The complete CHANGELOG is available here .
How to upgrade
If you have installed Gladys with the official Raspberry Pi OS image, your instances will update automatically in the next few hours. This can take up to 24 hours, so don’t panic.
If you installed Gladys with Docker, check that you are using Watchtower (See the documentation )
The complete CHANGELOG is available here.
