Just pull from git repo Gladys source code. Build and run server and frontend Then started first time web page: It pops up with email address and password fields. !? I have no idea where I should register user and password on my local machine. Any advice?
Hi @sigidagi and welcome to Gladys!
Are you sure the frontend is talking to the server and the server is successfully started ?
You should see a signup page
Frontend:
Compiled successfully!
You can view the application in browser.
Local: http://0.0.0.0:1444
On Your Network: http://10.4.64.38:1444
Server side:
Server listening on port 1443
No issues, it seems runnig
I see that you are using a custom domain (rock-5b.local), by default, starting Gladys frontend in development environnement will try to contact the backend on http://localhost:1443
See: Gladys/config.js at master · GladysAssistant/Gladys · GitHub
If you want to modify that to talk to the server on rock-5b.local:1443, you can add a .env
file in the front
folder and add:
LOCAL_API_URL=http://YOU_URL:1443
Then stop the frontend, and restart it
Thanks, now it works!
Perfect! If you want to have real time update in the UI, change also the websocket environnement variable so it talks to the backend too
Don’t hesitate if you have any other questions !
