Bluetooth Peripheral Configuration allows only creation as a presence sensor
Hello!
I tried to install RuuviTag sensor to my Gladys Assistant. In Bluetooth Peripheral Configuration ‘create’ button is not active unless I choose option ‘Use this device as presence sensor’. This device has temperature, humidity, air pressure and motion sensors. If I use the device as a presence sensor it seems that I can’t use it to trigger action based on temperature change. Is there something obvious what I am missing? Any tips how to proceed are very welcome.
Cheers,
saq
Hi @saq and welcome on Gladys :slight_smile:
This RuuviTag sensor is not handled by Gladys currently.
We are welcome for PRs if you wish to help us add this compatibility in Gladys :slight_smile:
